My PH has been raising pretty quickly so i decided to lower my TA.
When i started i had TA of 160 and a PH of 8.1.
I added muratic acid in my pool until PH reached 7.0. I did this in increments, ran the pump and tested again (my journey was 7.7, 7.4, 7.0 over two days).
I was worried about putting in too much acid at once, i read that it could concentrate in a pump or on the plaster floor and cause damage.
Once i reached PH 7.0 I put bubblers into my pool to aerate the pool per the TFP article: Lower Total Alkalinity - Trouble Free Pool
I ran them for a couple of hours on Sunday and tested in the evening. PH was up to 7.2 and TA was down to 130. I felt pretty happy about that.
The pump i used conked out so i had to go and get another pump which wont arrive until thursday. I got a couple of good hours or aeration in on sunday but that was it.
I'm going to make another go at making bubbles to try to get the TA to 90 this weekend.
the PH today Tuesday is 7.3 which is unchanged from Monday, but up from sunday evening which was 7.2 (sunday mid day was 7.0).
My plan for this upcoming weekend is that on Saturday morning I'll lower the PH to 7.0-7.2 and throw the stones in to aerate.
Is there any golden rule for how long i should aerate? Is a day enough? is this a multiday endeavour?
My manifold lets me use up to 6 stones in my pool generating bubbles from a pond compressor. It will push about 16 gallon per minute (or 1 Liter per second) through those stones.
Any thoughts on the plan?
Any ideas on how long i should anticipate aerating the pool with this scheme?
