- Jun 2, 2019
- 304
- Plaster
- CircuPool Edge-25
I lowered my TA from 110 to 90 - brought pH down to 7.2 using muriatic acid and used my waterfall to bring back up to 7.6 a couple times (seems like it lowers TA by 10 every cycle).
2 days ago my FC was 7.0 and my SWCG was set to 12.5% (or, 1/8, hopefully that equates to %) and runs for 8 hours, from the EoA it should be generating 0.5 FC.
I've been checking FC regularly and see at most 1-1.5ppm loss per day (probably not even that much, but I'm being conservative), so I would expect at least a measurement of 5ppm but I just checked and it's <1.5ppm. CYA is 60ppm. Will all that muriatic acid speed up FC loss?
I cranked the SWCG up to 75% to run for the next 13 hours to bring it back up to around 7ppm.
