Just got back to my Florida pool after being away for a while including a time with much rain and many drainings by a relative. A few things had drifted and I noticed that my PH was only 7.5 and the pool hasn't had an acid addition in a long time., in fact nothing acidic has been added including pucks. I found the TA at 40, lower than it's ever been. FC was 6.5, PH was 7.5, TA was 40, CH was 225, CYA was low (less than 30) and salt was 3600 with a water temp of 81 that calculates out to CSI of -0.72. I bumped the TA up to 80 (goal was 70), CH up to 250 and the CYA up to 50 (a good point for this enclosed pool).
My question is: did I overreact in bumping the TA up? Is TA=40 reasonable if the PH seems stable and doesn't drift-up and the CSI is in range? After adding the baking soda to raise the TA I ended-up adding acid to drop the PH back after it immediately rose to about 7.9
