Lower CYA
Perfect!
Hungry Back To School GIF by Papa John’s
When I do start slamming it, how often will I be adding in more liquid chlorine? Do I start this in the evening hours?
It is best to do it every 2-3 hours, particularly early in the SLAM. You can start anytime you have your kit. You can SLAM 24 hours a day if you like.
Print this out, read it three times, keep it in your back pocket...having hard copy really helps with questions in the moment...Link-->SLAM Process
Great. DE filters are notorious for clogging up quickly with organics. Note your backwashed/clean pressure. When you pressure rises 25% over clean pressure, backwash. If you clean pressure is 10, when it hits 12.5-13, time to backwash again.
Ok. I will do another backwash right now. 😀 How many lbs of DE powder should I be adding after each backwash?
If that is the cartridge style DE filter, it should be broken down and cleaned each time. Backwash is not real good on that type.
1lb per 10sq ft of filter area for clean filter. 80% if that if backwashed. As Marty says if cartridge it should be cleaned.
Oh ok. Was unaware of that. Thank you!
I had put 1 gallon of liquid chlorine in early yesterday afternoon and 3 more yesterday evening.
FC 8.36
TC 9.88
CYA 36
This morning, my pool is already looking clear and my totals were
FC 5.84
TC 6.38
CYA 36
I am supposed to receive my drop tester today.
Reactions: PoolStored
FC 8.36
TC 9.88
CYA 36
FC 5.84
TC 6.38
CYA 36
Does it look like I am heading I'm heading in the right direction since it is keeping a reading on the chlorine levels without slamming it yet?
Was your first FC reading before or after the 3 gallon of LC added?
Regardless, the testing indicated a drop over night. So the FAS-DPD will get better data and allow you to follow the SLAM process to completion.
The 1st reading I sent was 2 hours after I put in the 3 gallons in the evening. Earlier in the afternoon yesterday my readings were
FC .05
TC .34
CYA 36
