Hi,
I have an issue with the pool in our new house. This is an in-ground pool, irregular shape.
Pentair Challenger pump with Pentair FNSP 60 filter. The pool has two skimmers and one bottom drain.
There are 3 lines going into the filter. 4 lines coming back (3 for return and 1 for water feature).
There is very low pressure on the return lines. I know it should be much stronger. There is also low suction on both skimmers.
Not sure about the bottom drain, it is too cold to test.
The pump primes. There are no water bubbles. There is no pressure gauge, the previous owners plugged the opening on top of the DE filter.
I will purchase the gauge today. Pump works. I checked the strainers at the skimmers and the before the pump and it is clean.
There is a slow leak at the bottom of the impeller housing, probably needs a new gasket.
I had an in-ground pool before with a multi port valve on a sand filter. This filter has a pull up valve that opens on the bottom for backwashing.
I did backwash the filter for 3-4 minutes.
I did close 3 out 4 return lines but the pressure is still low.
Any suggestions on what else to check. I can blow the lines with a vacuum, check the impeller for any blockage.
I did open the DE filter and it looks dirty. Should I clean the grids? and add new DE?
THANK YOU!!!
THANK YOU!!!
