I just opened up my pool and the water is green. After running the pump for 24 hours, I tested my water and got the following results:
FC - 1
CC -.5 (how is this possible?)
TA - 40
PH - 7.8
CYA - less than 30 (pool store says it’s 18).
Questions -
1. Do I need to increase the TA since it’s only 40? If so, what TA number do I put in the pool math calculator to figure out how much baking soda to add.
2. Since I have to add stabilizer which lowers the PH, can I skip adding the muriatic acid? I hate adding it and would like to skip it if I can get away with it.
3. How do I tell what my CYA actually is? I can still see the dot at 30 but barely. Pool store says that the CYA is 18. All of their other numbers were spot on so I have a feeling that 18 is the correct number. It’s definitely not zero because I’ve seen what a zero cya looks like and this isn’t it.
FC - 1
TA - 40
PH - 7.8
Questions -
