pH- is dry acid. Poolmath can give you the dosage for that, if you want to use it up. Don't buy any more, but don't hesitate to use it, either. Muriatic Acid doesn't go bad with age, but the plastic jugs that hold it do. I'd want to get rid of that first, but be very, very careful because the jugs can get really brittle and disintegrate, and acid is nothing to fool around with. If the jug is on the verge of crumbling, there's no better way to get rid of it that by using it in the pool.
