So. Long story short, I did not have a chance to close my pool properly last fall. Naturally, when I tried to open it this spring, I had the Green Monster. A bit beyond green, actually. So I started to SLAM it, and it's at least cloudy green now and not OH WHAT WILL THE NEIGHBORS THINK? So I'm definitely on the right track, and need to keep going. That part is all good.
After a couple of days of having the filter basket just full of gunge and needing to be cleaned out several times a day, the skimmer basket is no longer collecting anything. The return seems okay.....a tad bit week, but enough to keep things going around on the surface. The pressure reading is 18psi, maybe a couple psi over normal, but nothing alarming. But in the skimmer basket.....seems like no suction, things just drift around in there.
I have an 18' AGP with a cartridge filter system. I am *assuming* I have simply overwhelmed the capabilities of my filter. I tried cleaning it, but nothing changed. I have a new filter arriving tomorrow. Am I on the right track? Is there anything else I should look at? I looked at the pre-filter basket, but that was clean as a whistle, so I am guessing the impeller is not clogged. Thank you!
