Hello I'm going to start with that this is my first year opening my pool myself. Everything was going great, until I set the mutliport valve to Filter and I forgot to put the plug in the sand filter. Needless to say the water dropped below the skimmer but was still coming out of the filter hole that had not been plugged. Now I have low pressure from the pump. There are air bubbles coming out of the return. I cleaned out the impeller by hand, not sure if anything else is clogging it. My pump cover doesn't have an o-ring and seems to be sealed properly. I can't seem to find an air leak. The only thing I can think is the pump is going bad that it was being run with water below the skimmer. It slowly fills with water then whooshes it away where you can hear when the water goes. It isn't moving fluid. Any help would be great. I have a Hayward Super Pump.
