Hi, turned put it all back together this year and there is very low water pressure from water coming back into the pool. I would say I'm getting about 20% of normal flow. Pressure on filter looks higher than normal.
We have the pump, catridge filter, propane header then back to pool. I've cleaned the filter in the fall and then again yesterday, it looks ok to me, not sure what it looks like when it needs to be replaced. Unscrewed all the pvc to make sure there wasn't a blockage. Nothing in skimmer or pump basket. Took bucket off pump and made sure impeller turned and nothing was stuck in there.
SIde note, propane heater just keeps cycling for 30 seconds, turns off then comes back on.I've turned it off for now. Could the heater be the issue with the flow as well? I've looked inside and can't really see if there would be a blockage in there. I have the input/output covered up over the winter so nothing could get in there. Maybe the cycling issue is from the low flow.
Don't know what else to check. Pool company isn't coming for another week, maybe I can fix before then and cancel that appointment. Thanks.
Heater - Pentair MasterTemp 125
Filter - Pentair Clean & Clear Cartridge Filter Only, 150 sq ft
Pump - Pentair Optiflow
