Low CYA - OK?
synapsid
70
Long Island, NY
Hi Friends,
All summer my pool has been great.
FC between 5 and 10, Salt between 2800 and 3000, equipment happily humming. OCLT showing zero loss.
CYA however is hovering between 30 and 40, and I never actually increased it beyond that level this year.
I believe it should be up around 60 or 70, and I would gladly raise it, but do I need to? I think a drawback of low CYA is that the SWCG must work that much harder to keep FC in the pool. If I add CYA, then perhaps I can back off on the SWCG?
I run the pump about 12h each day and the SWCG is set around 50%.
Thanks for any advice you all can give.
Need to? No. Lower CYA just means your cell has to work harder. Raising CYA extends the life of the cell.
Yes. I'd raise it to 60 or 70, raise it in 10 increments, test again after 48 hours before you do the next 10.
Reactions: synapsid
