A pool pro closed my inground pool yesterday. He encountered a problem during closing and had to drain my pool past my returns and fill the pool back up with water afterwards until water reached the bottom of my skimmer. I was worried that the water addition might have lowered my chlorine level and it looks like my fears were justified. After adding the polyquat, my chlorine level had lowered to 4 ppm, and after water was added, it lowered it down to 2 ppm. I’m concerned that it could go down more since I added polyquat which consumes chlorine and my mesh cover lets in some light and water. Since I closed with polyquat and my water temperature was 60 degrees at closing, how likely is it that I could develop an algae bloom over the winter that could permanently stain my pool? I don’t know an easy way to add chlorine to my pool since it is winterized and my loop lock mesh cover is hard to get on and off. I’m also concerned that if I added chlorine now, polyquat would consume the chlorine since it was recently added. I realize that I will probably open up to algae now but my biggest fear is that I will have stains that are impossible to remove if algae develops really soon and stays in the pool for the next 6 months. My pool pro thinks I will be fine without adding more chlorine as long as I open back up in mid April but I wanted to check on here to see what others think. Any advice would be appreciated.
