I have a Hayward C200S Cartridge Pool Filter. The other day it started making an extremely loud squeal. We moved into this house about two months ago and I do not know how older the filter is, it looks very clean. It is not the motor, it is coming from the filter. I have a video, with the audio, which I will try and post and a photo of the filter.
I turned off the pump and removed the top or dome section of the filter, there was nothing but water in the bottom. I took out the cartridge, looked at it, and did not see anything unusual. I put it back together and no squeal, until the next morning when the pool timer turned on the pump. Again, a very loud squeal. I did the same inspection process and no squeal. I went to my local “nationally known pool supply store.” They heard the noise from my video on my phone and said it was “the pump.” I explained after I opened the filter dome and put it back together it ran well for 6 hours. They suggested I replace the gasket and coat all surfaces with waterproof lube, which I did. It worked ok, all day yesterday. This morning when I started it up, the loud squeal was back. Stopped the pump, bled the system, took the dome assembly off, looked inside the bottom part, and put it back together and it ran perfectly all day. I put soapy water around the pressure gauge, bleed valve, and the areas where the top and bottom meet, with no bubbles, or indication of a leak. Any suggestions would be greatly appreciated. For info, I live in Palm Harbor, FL. No great variations in temperature. Sorry I can't attach files they are too large.
