Intake is weak.Filter psi is 8 to 10 post cleaning. It has been fine since last filter cleaning (5 weeks ago). It suddenly dropped to a reading of 1 to 2 psi yesterday morning. Catch baskets clean. No visible blockage.
Return is also weak.Shaw,
I'm not really sure what your questions is...
I suspect the dirt/mud is from the dirt that often gets into a lot of AZ pools...
Having 1 or 2 lbs. of filter pressure may, or may not be ok, it depends on your pump speed.
Does the water flowing out of a pool return feel strong or weak?
I can't think of any 'seals' that would cause any of this???
Tell us more...
And this is compared to the same RPM you ran the pump prior to cleaning the filter?Return is also weak.
Filter assembled correctly. When bled valve, air released until water released, but at a much lower flow from the release valve on top of filter.And this is compared to the same RPM you ran the pump prior to cleaning the filter?
If so, you may want to open op the filter and check to see if it's put back together properly.
If the pressure in the filter dropped and the return flow to the pool is weak - all other things being equal - there may be a restriction between the pump and the filter.
Or air compressor?Filter assembled correctly. When bled valve, air released until water released, but at a much lower flow from the release valve on top of filter.
If there is a restriction (blockage?), how do I clear the line? Snake it or get a professional?
THANKS!!
First is to see if you can locate the issue.Filter assembled correctly. When bled valve, air released until water released, but at a much lower flow from the release valve on top of filter.
THANKS!!
