We have a lot of issues with our pool that I think (hope) are related:
1. We've been losing about 1/2 inch water a day. This happened last summer too, we dug up the pool lines we could access and had someone check for leaks in the pool. Couldn't find anything substantial.
2. When the pump turns off, the pump basket empties and it sounds like the water is rushing out of the sand filter. When it turns back on, it takes 2-3 minutes for the water to pull back through the pump.
3. When we backwash, some water dribbles out of the ring below the valve, as well as the clear glass. We've tightened as much as we can with tools.
4. It sounds like a slight whistle from the glass and valve, the psi sits at 11 which is slightly lower than usual.
I've read a bit on here, and it perhaps could be the spider gasket, but I'm not sure where to start the trouble shooting. I also don't know how we can be losing so much water a day. The dirt is wet under the sand filter, but again, not THAT much water. The pump & filter sit above the pool water line (I saw that asked a few times)
Since I don't know exactly what's going on, I've been guessing search terms for the forum. Spider gasket issue was the one I saw the most. I appreciate any help! Thanks!
