Hi Everyone,
Hoping someone may have an idea on what If any issue my pool is experiencing.
I have 24ft above ground round pool. I live in Massachusetts, and the pool is covered in the winter months with a high quality cover (new one is purchased every year) with a pillow in the center of the pool. Return is closed, and skimmer is cover as well.
I’ve noticed significant water loss; to the extent that I have to put the hose in multiple times over the course of the winter. When I took the cover off in the spring, the water level was only approximately knee height; for reference I am about 5ft 4in. We were never able to find a tear or leak, nor any suspicious wet spots or saturated areas around it. But since the liner was faded, I had a new one professionally installed in the spring along with the foam padding between the wall and the liner.
The pool was closed this year right around the third week of September. While the water loss does not appear to be as significant as previous years, I’ve still had to run a hose twice since closing it, for a couple hours each time to bring the water level back up. I do have a cover pump to drain the rain water but it is not left on. I turn it on to remove water from the cover when needed and unplug it once the water is off the cover.
While I do have to put the hose in from time to time during the months it’s in use, the loss over the winter months seems excessive to me.
Is it normal in the north east for an above ground pool to lose significant amounts of water over the winter? Could it really be all attributed to evaportion? Perhaps from air and wind getting under the cover? I would have sworn it was a leak somewhere and really thought so I’m previous years. But I’m honestly not so sure now, seeing as it’s a brand new liner and was professionally installed.
Any insight or thoughts would be greatly appreciated.
Jenn
Jenn
