I dont think i understand bather load?
This is an inflatable, it doesnt remove water surface debris from soaks super well. When I've added chlorine, I get alot of foam, which I skim off the surface. The water looks clear, there is just some dead skin after soaks. Started reading about acceptable FC loss, grew concerned, shocked tub. Other parameters have not changed, water is still balanced.
7/14 tub at 8pm is 3.5 FC | 7/15 Next morning tub is at 2.5 Still using dichlor to raise CYA at this point Raise to 4 FC via dichlor Soaked 45 minutes midday 2 people bathed .5 FC When they got out Added dichlor to raise FC to 4 8:33 PM Tub is at 2 FC Dichlor raised to 4 ppm 2 people bathed soak for 45 minutes 2.5 FC when they got out Dichlor to raise FC to 4 | 7/16 8:45 PM 1 FC Dichlor to 4ppm 2 people soak bathed 30 minutes tested 3 FC Dichlor to 6 FC | 7/18 7:30A 1 FC Dichlor to 5.5 FC 9:00 PM - 3 FC and .5 CC Switch to bleach CYA now 30, confirmed via test Add bleach to 7 FC | 7/19 - 11:30 pm 2 FC - .5 CC Up FC to 12 via bleach | 7/20 11:30pm 5FC |
