Need a good diagnostician
When I turn off my pump to backwash, the water level by the pump strainer basket goes down, I hear a hiss from the filter, and water is rushing through the multiport valve for a few seconds. It was never like that in the past. If I wait until it stops and turn to backwash, it loses pressure completely and takes a minute or two to prime.
If I turn the multiport to backwash while I hear the water going slower but not fully stopped, it doesn't lose completely pressure and pumps right away when turning the pump back on (I know not a great idea to move the multiport before it completely stops). When in filter mode, there isn't any water going through the backwash hose which I assume would be if the multiport gasket was shot.
I cleaned out my filter which was full of DE so I know that's not the issue.
I'm in middle of opening my pool, and my filter pressure gauge is frequently getting high, if that helps with diagnosing.
The filter is definitely working, as the water is clearing up even though I didn't balance yet, but there is a ton of dirt I'm trying to deal with first (which is another reason I'm thinking it's the multi port).
Does this sound like a multiport issue, air getting into the system (or both) or something else?
Thanks!
Thanks!
