Lurked around for years but new to the forum.. 24' above ground metal sided.
Year before last I started losing a bit of water but it seemed intermittent. Just topped it off as needed and went on. It got worse last year and I was having to add water daily-ish to keep it to filter running level. It stayed so cool from the constant top offs the family didn't use it much. Was a constant battle to keep the skimmer from gasping. I noticed that I had washed out the sand directly under the skimmer, so I removed the skimmer and cleaned and changed the gaskets. No dice. As the pool was 7 years old, I said heck with it, I'd replace the liner this year and didnt even bother winterizing last fall. Last week new liner arrived. I completely drained and removed the old liner, fixed the washed out area, and reinstalled the brand new liner. I bought and installed new "universal" 2pc rubber gaskets from the pool store. At install I noticed the faceplate had a small crack or two but proceeded. Skimmer, gasket, metal pool wall, liner, gasket, faceplate. Got everything mounted up topped it off and BAM the next morning it was down enough that the pump was getting air. I bought a new face plate and installed with the 2 rubber gaskets but this time used a bit of clear silicone RTV. Topped it off and next morning same thing (low).. I noticed it seemed that one of the bottom skimmer screw was almost stripped so I ordered a complete new Hayward skimmer kit. It came in so I drained it just below the faceplate. Removed all the old, cleaned all in and out. Installed the new silicone 1 pc butterfly gasket that came wth the new setup. Lined everything up snugged it down good and filled it up. I fired up the pump and marked the water level in the skimmer with a pencil. 2 hrs later I go back and and it's down between a little under a 1/2"... In 2 hrs! It has been cool and rainy the past couple of days so hard to look for wet areas.. I am spent. Any ideas of things to check? Thanks in advance.
