Seeing several threads about rusted out walls.
This is what keeps me paranoid about our pool. The liner doesn't have to have a leak to be a problem. With a beaded liner there are gaps between the bead reciever where water can get in between the wall and liner and it has no where to really go.
Any normal swimming and splashing gets water up over the bead and it has no where to go but in these gaps.
I've been spraying silicone and wd-40 in them to try and help protect the wall but through some of the bigger gaps I'm starting to see some surface rust.
Thinking about putting some silicone over these gaps where the bead reciever buts together. I'm thinking that it would at least prevent a large majority of the water from finding its way in there and rusting out the wall.
Thoughts? Would running silicone all around the top of the bead as well as those gaps be a good idea or no?
