- May 18, 2016
- 22
- Vinyl
- Solaxx (Saltron) Resilience / Aquacomfort A5
I presently have a Hayward Super Pump 1.5 hp single speed pump on my inground pool, which is 22,500 gallons with 1.5" plumbing. My skimmer and main drain are probably 50'-60' from the equipment. I added a solar heating system on a rack (not up on the roof). Obviously the flow is a lot less when the solar is in use, but I would still like more flow for when it is not in use. I was thinking of going to the Hayward Super II pump. Even dropping to 1HP, it still moves slightly more water than what I have now without going overboard. Not sure if the Super II 1.5 hp would be too powerful though given my pipe size. Any thoughts or suggestions?
I also have a Raypak gas heater, so dual or variable speed pumps won't work for my application because of low flow rates.
