Hey guys! I’m new to the forums and a new pool owner. I bought a 1964 ranch just outside of Atlanta GA and did a 6 month renovation. The house is practically new but the pool is another story. It was built around 1965 by Artistic Pools in Atlanta... a reputable builder still in business. The pool is gunite 40x20 rectangular and approximately 35,000 gallons. The neighbors tell me it was built as a heated pool and has 20 return fittings - 6 in the pool floor and 14 around the perimeter. The heater was removed years ago and the pump and filter have been replaced over the years but could use an overhaul. The pool has 2 skimmers and one main drain. I believe the pool is called a flooded system... the pump house is behind the pool about 6 feet below the pool level. I went to Artistic Pools to see if they still had a blueprint to get an idea of how the pool is plumbed but they couldn’t locate anything in their archives. The pool appears to have been plumbed with 2” schedule 80 PVC... it’s grey in color. At the pump house I have one 2” line coming from the main drain and one 2” line from the 2 skimmers which are tied together somewhere underground. There is one 2” line returning to the pool. All of the 20 returns appear to be plumbed with 1” schedule 80 PVC and they have 3/4” fittings on them. The fittings originally had some type of screw on restrictor but at this point none have a restrictor. The opening on the 20 returns is 3/4” and the inside diameter of the piping to the returns appears to be 3/4” or slightly larger so I’m not certain of the true pipe size for the returns. I don’t know if the plumbing under the pool for returns is 2” with 1” branches tied to the returns or the entire plumbing for the returns is 1”!? I am doing a DYI reno on the pool and it currently remains crystal clear with no issues balancing the chemicals. The only issue I have is that there is zero water movement when the pump is running so I get a lot of surface debris which stays stagnant and doesn’t move towards the skimmers. I have inserted 3/4” winter plugs into the returns and have confirmed all are working. If I close all but 2 of them I get pretty decent flow out of the 2. I am planning on replacing all 20 fittings with eyeball fittings which can be closed or opened. The current old pump is a Flotec 1 HP and the current old filter is a Pentair Nautilus FNS 36 DE. I estimate between 50 and 60 feet of head but am worried about increasing the pump HP since the return plumbing seems so small although there may not be as much resistance since there are 20 returns?! I was looking at the Pentair 011018 VSP 3 HP pump with the thought that I could get it set up and turn down the RPM to get just the right flow. Anyone out here run into this type of setup from the 60’s who might provide some advice from personal experience?
