Hello - longtime lurker, first-time poster. After receiving a few quotes from pool companies somewhere in the $90K - $150K range for a basic medium-sized pool (no upgrades), my family and I are looking to somewhat-DIY install an in-ground pool from Pool Warehouse. We are planning to subcontract all the grading/excavation and concrete work. This will be our first pool, so we need some advice! We built the pool package that we think is perfect for us on Pool Warehouse, and would like some input on what we are missing or need to upgrade (or even just what we need to consider). Please take a look at the package below, and provide any insights you have.
We appreciate your time!
Pool Walls | 42" Polymer | $ 10650.00 |
Pool Direction | Direction - Turn Left or Curve Left, From Shallow End | $ 0.00 |
Pool Liner | Liner - 30 Mil - Samara | $ 750.00 |
Pool Bottom | Bottom Dig - 42" Wall Standard Diving Pool 3'4" Shallow End With 8' Deep End | $ 0.00 |
Corner Radius | Corners - 6" Corner Radius | $ 150.00 |
Pool Coping | Coping - Cantilever Coping With Foam Concrete Forms 20'x40' And Up | $ 695.00 |
Pool Wall Braces | Braces - TURNBUCKLE Brace With 20 Deck Supports (Pools Up To 20'x40') | $ 395.00 |
Polymer Pool Step | None | $ 0.00 |
Liner Over Steel Pool Step | Steel Step - 24' Wide Open Pour Top Step And Tanning Ledge | $ 3195.00 |
Step Location | Location - Center End Of Pool | $ 0.00 |
Pool Bench/Swim Out | None | $ 0.00 |
In Pool Spa | None | $ 0.00 |
Spill Over Spas | None | $ 0.00 |
Pool Step Jet Kit | Step Returns & Step Jets - 4 Grey Spa Jets With Air Intake For Polymer Steps | $ 255.00 |
Deck Jets | Deck Jets - 4 Deck Jets | $ 395.00 |
Pool Pump | Pump - Variable Speed Hayward Tristar 2.7THP Vs950 Pump | $ 1050.00 |
Pool Filter | Filter - Hayward C5030 SwimClear Cartridge Filter, 150 GPM, 2" | $ 995.00 |
Pool Skimmer | Skimmer - 2 Grey Aqua Genie Skimmer And 1 Grey Return | $ 335.00 |
Chlorination & Automation Systems | Chlorination - Hayward OmniLogic Cat5 Smart Phone Controlled 40k Salt System | $ 2225.00 |
Pool Plumbing Kit | Pool Plumbing Kit - 2" Platinum Plumbing Kit w/ 6 Valves, 200' FLEX PVC, & Salt Anode & Water Bond | $ 825.00 |
Pool Cleaner | Cleaner Style - Hayward AquaVac 650, Touch Free Canister, With Caddy And Smart Phone Control | $ 1350.00 |
Pool Lights | Light - 3 Grey Trim Nicheless 1.5" Color LED Lights 50' CORDS 12V | $ 1035.00 |
Light Accessories | Light Accessories - Hayward Junction Box | $ 75.00 |
Pool Heater | Heater - Hayward Heat-Pro Electric Heat Pump 110k btu Round Base | $ 3695.00 |
Pool Diving Board | Diving Board - 6' Grey Diving Board With Flyte-Deck II Base | $ 895.00 |
Slides | Slide - Riptide 7'8" Tall Gray, Left Turn | $ 4195.00 |
Pool Alarm | Poolguard In-Ground Pool Alarm PGRM-2 | $ 249.99 |
Pool Handrail | Handrail - 2 Deluxe Stainless Steel Handrails w/ Polymer Anchors | $ 150.00 |
Pool Ladder | Ladder - 2 Deluxe Stainless Steel Deep End Ladders w/ Polymer Anchors | $ 150.00 |
Pool Wall Padding | Steel Padding - 42" Walls, 2 Rolls Foam Padding (250'), 4 Cans Adhesive & Seam Tape | $ 195.00 |
Maintenance Kit and Start Up Chemicals | Kit Style - Deluxe Maintenance Kit with 40,000 Gallon Start Up Chemical Kit | $ 180.00 |
Safety Rope Kit | Safety Rope Style - 22'-24' Safety Rope w/ Bullnose Rope Eyes | $ 0.00 |
Lift Gate | Lift Gate Service - Curb Side, LTL Freight Unloaded by Customer With Lift Gate, Fork Lift Needed | $ 50.00 |
Shipping & Lead Time (Polymer 16 Weeks Minimum, Steel 16 Weeks Minimum) | Shipping & Lead Time (Polymer 16 Weeks Minimum, Steel 16 Weeks Minimum) - Non-Western State | $ 0.00 |
3d Swimming Pool Layout | None | |
