- Mar 30, 2012
- 25
So I have a picture of my pool below that was taken on June 19. This was 2 weeks after the initial opening.
So some background information, weather here in southern Indiana went from ice and snow in mid-April to torrential rain and flooding in early May
As a result, I didn't get to open my pool in late April/early May like I would prefer.
Work schedule also caused a bit of delay when the weather started to turn springy (lasted less than 2 weeks around here)
So I didn't get the pool opened before my dog decided to jump into the cover and rip it apart.
We were lucky she didn't drown but it did force me to open the cover and begin the opening process Wednesday (after Memorial Day, which was may 30th)
When I removed the cover, I tested the water [CYA ~25, pH ~7.2] which was typical for when I opened, so I began adding liquid shock to get to 20ppm.
Due to the damaged cover, and late opening there were many tadpoles in the pool, they didn't survive the shock very long but took quite a while to remove.
I did notice that the pump/filter was acting abnormal, whenever I turned off the power to the pump motor, I would get a back pressure of water spraying out the skimmer.
I thought this was because it was just due to the skimmer basket being full and the pump sucking air but noticed the basket didn't have to be as full as usual for this to occur
After 1 week had passed, I started suspecting I had filter issues so I removed the multiport valve to check the sand and it looked good from the side that I could check.
The filter is under our deck and difficult to get into without completely removing its plumbing.
The following week (June 18) I was using the leaf rake to just make sure I had all the leaves out I grabbed quite a bit of sand and knew that I had damaged laterals
So I replaced the standpipe assembly and sand and then took the picture that is immediately below.
It has been a week and a half since turning on the filter/pump after the repair, and the pump is acting normal except for the lack of pressure building.
I would have expected to have to backflush by now but there just hasn't been a reduction in flow from the outlet.
My shock consumption has reduced over the last week or so but its still being consumed faster than if the pool was clear, so I know its still fighting algae.
However, the next picture shows pool in current state and makes me wonder if I have yet another problem or if I just need to continue the SLAM and be patient
There doesn't appear to be progress, other than leaves deposited from the recent storms.
Several years ago I learned how to maintain my pool "trouble free" but now I am having doubts. I know fighting algae in warmer temperatures is more difficult
But I figured I would consult the experts and see if I am missing something!
I have kept the FC above 15 the entire time, and have almost consumed an entire bottle of R0870 lol
Oh and I almost forgot, yes I brush daily and no, I haven't vacuumed. Reason being, I don't want to vacuum the old sand that is on the bottom and overfill the filter.
Thanks for your assistance!
Steve
Steve
