Does the Pool Math app’s recommendations “reset” with each additionally logged test result and corresponding additions?
What I mean is: I logged TF-Pro results on 5/9 and tested for everything - FC/CC/pH/TA/CH & CYA. That reading recommended 3.7oz of dichlor and 30 oz Borax which I added both.
Today I only tested for FC/CC/pH (to see what impact my addition of dichlor and Borax had) and got the following results:
FC - 0.5
CC - 1.0
pH - 7.2
The recommended dichlor addition per the app was 6.4 which happened to be double the recommendation from my 5/9 test. The pH also recommended again 30 more oz of Borax. I did tell the app that I had added the recommended 3.7 and 30 oz from the 5/9 read, so is the app not taking into consideration what I’ve already added? And the recommended additions will just continue to add up every time I test?
Hope this makes sense!
FC - 0.5
CC - 1.0
pH - 7.2
