- Aug 18, 2023
- 14
- Plaster
- CircuPool RJ-30 Plus
2,Just to clarify, installing it on the pool side would be here, correct?
If your spa is average in size (500 -750 gallons), two people using it for 20-30 minutes can use up all the chlorine if the level is 3ppm and nothing is being added. Regardless of how clean a person may be before entering the hot water, one immediately starts to perspire and generate more body oils that the chlorine quickly reacts with and gets use up.Thanks Jim, That was my thought as well, that I could just adjust the SWG in the event of a big prolonged spa party
Tom
