Load Shedding Pump While on Generator
NCbob
1
Hi!
I've a Pentair system, no heater, 100% conventional. When running on the whole house generator, I want to shut the system draw down (pump) but not install a contactor and interrupt the AC line. The reason for this choice is accessing the power feed for the install would be highly invasive at this point. Similarly, I don't want to add a contactor that I have to seal up directly at the pump. The load management system sheds unnecessary loads (2nd AC, 240v air compressor, etc.) but the pool pump isn't part of the system.
I have one set of dry contacts available from the transfer control system. Is there a convenient way to essentially "disable" the pump using those dry contacts through interfacing with the Pentair? Without using a relay, the dry contact location is at the transfer switch, about 100' away and is not rated for any significant current.
Thoughts?
Welcome to TFP.
List your specific model Pentair equipment you have - pump? Automation?
Post pictures of your equipment pad.
