16000 gal vinyl liner pool, just had 2nd liner put in this spring after 15 years. Having problem keeping chlorine levels steady. Ph also creeps up after a few days. My alk is 121,,,CH a little low at 144...CYA steady at 45. I use liquid chlorine as the tabs raise the CYA over time. Never had this issue before once I got levels balanced at start up no issues thru the summer. Any ideas out there Problem is chlorine does not hold even for 24 hrs Ph climbs even though ALK is ok????
