I seem to have a suction side air leak problem, looking for advice on how to deal with it.
This is a 15,000 gallon pool with a single skimmer and a single main drain. There is a suction-side Jandy valve that allows me to select the skimmer, the main drain, or both. The skimmer has a Pentair Vac Mate (vac plate) which supplies suction to both the skimmer and an ancient Hayward Pool Vac Classic. There is a lever in the Vac Mate that allows me to restrict the skimmer flow, which diverts more of the suction toward the Pool Vac.
The Pool Vac seems to need things configured so that it gets the lion’s share of the suction. Otherwise, it gets stuck on the main drain (old style flat drain cover). The problem is that when I configure it that way, I get air bubbles in the pump basket, and I can also hear air bubbles moving through the Jandy valve.
The good news is that when I reduce the vacuum directed at the skimmer, the air bubbles go away. For example, if I flip the lever in the Vac Mate to allow maximum flow through the skimmer (reducing vacuum), almost no air bubbles visible at the pump and no air noise going through the Jandy valve. The problem with that configuration is that the Pool Vac goes slower, doesn’t climb the walls nearly as far, and gets stuck on the main drain.
I considered that the air might be coming from the hose attached to the pool vac. I can’t prove that I’m not (also) getting air through the hose, but I disconnected the hose and plugged the hose side of the vac plate, and I still get air. So I’m thinking it’s probably leaking in underground plumbing somewhere between the skimmer and the Jandy valve. Digging would entail tearing out a concrete deck, so isn’t exactly my first preference.
It might also be leaking at the (25 year old) Jandy valve. I tried spraying it with a garden hose to see if that had any effect on the air noise – it didn’t, but I’m not sure that this is a valid way to test. I haven’t seen any indication of water leaking from the valve when the pump is off.
I’m contemplating that my best option might be to find a way to operate the pool vac without requiring so much vacuum. I’ve thought about replacing the drain cover with an anti-vortex design, but not sure if that would make things better or worse. Hayward has a retrofit kit that is supposed to make the pool vac work better at low flow: http://www.hayward-pool.com/shop/en/pools/v-flex-upgrade-kit-i-vfupkit
Does anyone have experience with this “v-flex upgrade”? Is it worth the investment? Or should I consider completely replacing the old Pool Vac with a newer model?
Thanks in advance.
Thanks in advance.
