Still getting used to this stuff. I've been adding liquid chlorine instead of using the pucks as i was trying to avoid CYA. But doing the dot test from my kit, I'm not sure I have any CYA or at least I can fill up the tube and still see the black dot.
Should I buy a bucket of tabs for use to add chlorine and also this will up my CYA levels?
do I not worry about it, water is clear and right now adding about .5 gallon per week of 10% liquid.
Do I need to wait until it gets warmer and then start thinking about my CYA level?
Thanks all for the help
