When wanting to raise CYA by a little 5-10ppm what’s the best way about doing this? Liquid or dry stabilizer? I’m reading between 25-30ppm this morning. Is this low enough to even worry about?
I would put the amount of CYA powder needed to raise your level by 10 ppm in a sock and hand in the pool. If you have a skimmer put the sock in that .
Your other option, depending on how your pH and TA act, is to use a floater and trichlor pucks to add FC and CYA simultaneously. Use Effects of Adding Chemicals in Poolmath to see the effect of each puck.
