Liquidator Question?
May 16, 2013
18
Barto, PA
I've been running a Liquidator for several years. I clean the tank out each season however the throughput seems to slow each year. It really can't keep up with the. chlorine requirements. The pool is 32,000-gallon gunite/cement. The flow is 70gpm and I run the pump from 6AM to 6PM. I have seen upgrade kits for the Liquidator to go to3/8 tubing, I believe mine is 1/4. The kits I see just show a shut-off valve, 2-check valves, and 2 fittings. Two questions:
  1. Does the upgrade really help?
  2. If upgrading what about the fittings on the tank and the flow meter that are all 1/4 inch?
Regards,
Cal Settle
I have the 3/8" upgrade, and I think it's a worthwhile improvement. If you don't have one already, I would strongly recommend buying a needle valve to replace the standard shutoff valve.
I didn't have any problems attaching the tubing to the tank or flow meter.
Reactions: calsettle
Thanks for the reply, I'm going to try the 3/8 upgrade and see how well that works.
Regards,
Cal Settle
