Well...I may end up removing the liquidator.
No matter what I try, I cant get the inlet to keep up with the outlet...so my flow maxes at about 3.5...which does not keep up with my chlrine demand (4ppm in full sun).
Inlet check valve is the issue. It's working, but just not allowing enough flow to keep up. When I pull supply line I get plently...but going from check vlave to LQ is much lower. I ensured the check vlave was working and even swapped with the other from the kit...no go.
So if I push the LQ outlet float down, I get plenty of flow...and if I let the LQ fill up a bit, it will max out...but eventually the flow level comes down and outlet throttles back flow.
Maybe a better check valve?
Is 4ppm on 17k pool rel;aistic with LQ?
Go to Stenner set up?
