Liquid stabilizer for spa CYA?
Vesuvius
113
St. Louis/MO
Pentair Intellichlor IC-40
I've been using di-chlor for CYA in my spa but is there any reason I shouldn't use liquid stabilizer in scenarios where I want to take CYA from 0 to target much more quickly than via multiple di-chlor doses? Thanks
5 ounces of liquid stabilizer in 500 gallons will give you 30 CYA.
You need to measure carefully to not overshoot your CYA target.
Also know that the goods clump up on the bottom of the jug and it's darn near impossible to dose as you hoped. You either pour water, or concentrated sludge, no matter how much you shake the bottle. It's really best for full gallon doses where you can rinse the bottle well after to get it all.
Yes, will do--thanks
