Nope. That is another way to figure how much muriatic acid you need, instead of plugging pH and TA into the pool calculator. Sorry.ndully said:Will the Acid demand test on my 4 way test kit test for CYA? (I love saying that btw, in my line of work it means something different
ndully said:On Tuesday, I put in two 1lb bags of Suncoast Super Shock 4-Way Sanitizer and treatment along with 1 gallon of muriatic acid. On Wed, I added a gallon of liquid chlorine, another gallon muriatic acid, and 4lbs of Suncoast stabilizer/conditioner. The test kit I have test for Chlorine, ph, alkalinity, and acid demand. It looks like I will be heading to the pool store in the morning to try some Drop Down?1?!???
I'm sorry, but without your own test kit, you're going to be stuck on the expensive pool-store merry-go-round all summer long.You can't mix our philosophy with the pool store's. I will not be replying to this thread anymore. It's just too painful to read.ndully said:I know little when it comes to this stuff. The ph was 7.4 on Tuesday when the water was tested. On the print out it said to add 1 gallon of acid and then wait 8 hours before adding the other one. I just did what they told me. I am getting the water tested again in the morning as it has been 72 hours since I have added anything. I will post the water results then and hopefully, get some more feedback from you all. They want to me to buy the Suncoast Drop Down product...they said that on Wednesday.
Richard320 said:A little inspiration:
pretty-black-pool-t58442.html
first-time-pool-owner-t61565.html
a-little-encouragement-for-those-with-algae-and-new-to-bbb-t57137.html
frog-filled-green-swamp-to-oasis-work-in-progress-t48213-20.html be sure to look at page 2
before-and-after-t36785.html
a-final-picture-set-of-how-well-the-bbb-method-works-t33199.html
You don't need mega-blaster-hyper-shock-miracle-powder nor any algaecide. Kill the algae, kill it all dead, with bleach and you'll be fine.
Wanted to add some other comparisons to the original question. Our former pool guy lost his storage for liquid chlorine and began using the powser chlorine only. He insusted the trichlor was better since its more expensive. I noticed significant etching in the plaster while a strange grey buildup was forming in crevices and dormant areas on the plaster. The infloor popups were failing at a rate about two a year. After a few years I fired the guy and do the pool myself. Use liquid chlorine in a "Liquidator", and muratic acid. no tablets, nothing else. the plaster ceased deterioting and have replaced two popups in the past four years.The liquid seems to work so much better than the powder shock! But, when you have two seater car and are in work clothes to pick it up, the powder is just so much easier! Any thoughts?
