- Mar 5, 2020
- 3,221
- Plaster
- Astral Viron V35
There is an inconsistency in the interpretation of the entered bleach strength between the FC-tab in PoolMath's Home overview and the Effects of Adding, that sometimes creates confusion, especially for members outside of the US.
In the Home section, everything makes sense. Bleach-percentages above 9% are interpreted as Trade-% (g Cl₂/L [%]), Bleach-percentages of 9% and smaller are interpreted as NaOCl weight-% (g NaOCl/g [%]).
This reflects the custom that liquid chlorine with 10% and 12.5% strength is usually sold specifically for pools, and the Trade-% is easier to use to calculate PPMs.
Liquid chlorine with strengths below 10% is usually sold as household bleach, and it seems to be labeled as NaOCl weight-% in the US.
Percentages of 9% and smaller, PoolMath internally transforms into Trade-% to calculate the resulting PPM-change in a given pool volume:
But in the Effects of Adding, PoolMath only "knows" the bleach-strengths that are typically used in the US: 5.25% (NaOCl weight-%) for which 5.4% (Trade-%) is used, 6% (NaOCl weight-%) for which 6.17% (Trade-%) is used, 8.25% (NaOCl weight-%) for which 8.49% (Trade-%) is used, 10% (Trade-%), and 12.5% (Trade-%).
Any entered percentages that are different to above values get "rounded" to one of these values. The following graph shows which Trade-% PoolMath uses depending on the entered bleach-percentage:
For example, any percentage larger than 12.5%, PoolMath will interpret es 12.5% (Trade-%).
I remember a member using 15% bleach who got confused about the differences between Effects of Adding and the Home-section.
In Australia, household bleach gets sold as 4.0 Trade-% (Trade-% and NaOCl weight-% are actually pretty much identical here, but Australia makes things more complicated by labelling it additionally as NaOCl volume-% (42 g NaOCl / L)). But when entering 4% into PoolMath's Effects of Adding, Poolmath "rounds" that to 5.25% bleach (NaOCl weight-%) and uses a Trade-Percentage of 5.4% for the PPM-calculation - resulting in wrong PPM values for an addition-calculation. In the Home-Section, the calculation results are correct when entering 4%.
Is it possible to implement the same bleach-strength interpretation in Effects of Adding that is used in the Home-section?
