22,000 Gallon outdoor inground pool, new sand filter, here are my test results with the Taylor test:
FC ~ 0
CC ~ 0.4
CYA ~0
pH 7.6
TA 275
CA 400
A few days ago I added Dichlor and Muriatric Acid to get the numbers to what they are now.
Obviously the cholorine/CYA and TA is out of range.
1. What is my best course of action given the above? I'm guessing I need to add chlorine/CYA and find a way to higher the pH then use Muriatric Acid to lower pH/TH.
2. Except for aeration, is there a way to increase pH without increasing TA?
Thank you,
Dragos
FC ~ 0
CC ~ 0.4
CYA ~0
pH 7.6
TA 275
CA 400
Thank you,
Dragos
