I’ve been finding an unusually large amount of debris on the bottom of the pool which requires vacuuming 2-3 times a day. The debris looks like dirt, as if someone is throwing a handful of dirt into the pool and it settles at the bottom. I’m also pretty sure I have a leak, but I can’t find out where.
Is it possible that the leak is in one of the seams on the bottom and sand or dirt is getting in as water is leaking out?
Thanks in advance.
24’ above ground pool with vinyl liner.
Thanks in advance.
