Hello everyone!
We bought a new home about three years ago and it seems we have had nothing but issues with the liner pool in our new home.
First, we started losing a ton of water and had American Leak Detection come out and they found that the pool light gasket was leaking.
So, in December 2022 we had a new liner installed.
About a year later we had more water loss. We had a leak detection pool company in the Dallas Ft Worth area come out and they found that the pool light was leaking again.
They put epoxy around the entire light and so far, water seems to be holding, but I am not 100 percent positive we aren’t still losing water. Bucket Test seemed to show there wasn’t a leak several weeks ago, so that’s good.
We had some crazy storms come through last night. Now, we have water behind our pool liner, mainly in the walls. We made sure to drain the pool before it reached the top/bead track, so we assume this is from ground water.
I attached a few pics.
1. Should we just let the water go away on its own? I really don’t want wrinkles in a basically new liner
Would it be better to get a shop vac or sump pump and try to vacuum the water out while using a broom to manipulate the liner back ?
2. I also attached a picture of our pool equipment. We don’t have anything installed like a vacuum pump that would prevent this from happening again, do we? There is one extra pipe we aren’t sure where it goes/what it does.
3. If we don’t have something installed in our current set up, would you all recommend we hire someone to install a sump/well pit? We asked the person who installed our liner his opinion on install one a sump pit and he didn’t feel there was enough ground water at that time to warrant it, so he didn’t install it, but said he would if we needed it (I am not sure if this company is even still in business).
4. Are there any pool liner companies you all recommend in the Dallas Forth Worth area here in Texas? We don’t have anyone in our city that deals with liner pools and it is so frustrating!
Thank you for any help you can provide!
Emily
Emily
