Hi. Our pool light stopped working so I removed it to ensure everything is fine, which it is, so jt must be a bad LED bulb. When I go to screw the light back in, the screw won’t catch to the niche housing (the threads appear to be fine) and the screw just slides in and out as if the housing is stripped but it’s not even close, so not sure how it could’ve stripped out so bad when it had been just fine. When I look online at replacement screws, there appears to be a rubber gasket on some, but I don’t understand how that would get the screw to catch. Anyone have thoughts on what happened and more importantly, how I fix this? Thanks in advance!
