I have an 11500 gal plaster pool with SWG.
I had a leak last summer around my pool niche that was fixed with epoxy. Hurricane Ian and the high volume influx seems to have aggravated this- I am losing about a 1/4 inch per day. A local leak detection company came to eval today and state a crack has now formed around the niche that is too large for an epoxy fix. They are quoting $925 to drain to light, remove epoxy, apply Plast-Aid, Fiberglas and resin and appropriate sanding, vs the suggestion to replace the niche altogether (quoting $2975 for this option, but they do not offer it and would be outsourcing it).
Is there a correct answer, repair vs replacement? I am betting I could call around to get a better price on niche replacement by cutting out the middle man, but I want to make the best long term choice rather than the cheaper immediate choice if it comes with more headaches
