Opened to clear pool. (Thank you!) Couple of leaves. Water drained out by 1/3 (plug pops out of light/ return every year). Filled pool added liquid chlorine. Vacuumed with my new e10 robot. Ran filter several hours.
FC. 7
cc. Less than .5.
Ph. 7.4
TA. 60
CYA. Could barely see dot at 30. (Hate that test)
so im assuming cya is close to zero. Will add liquid stabilizer. It's from last year. Just keep shaking the bottle to mix? What's the best way to add it?
TA will rise a bit by itself? Not to worry?
Am I correct in thinking I don't need to slam?
Thank you again for my clear pool. Just wanted to make sure I got this right
FC. 7
cc. Less than .5.
Ph. 7.4
TA. 60
