Let’s see your water after removing winter cover!! **RESURRECTED FOR 2025!**
Mine was clear, but had al algae ring around it. The FC was just 1.5PPM. I went a little bit overboard wanting to avoid an Algae bloom and SLAMMED it with 3 x 121oz jugs of 7.5% chlorine and 2 x 1lb bags of 58% Cal-Hypo.
After overnight the FC is now 33PPM. The PH is sky high at about 8.5.. That's okay. It'll take a couple of weeks anyway to get it vacuumed and temp up to swimming levels. The water is about 57 degrees.
Is your cya above 80? If not it sounds like a bombing not a Slam. Not more effective just more risky and more expensive. Just trying to clarify for other readers that this is not recommended.
* The phenol red Ph test is inaccurate at fc levels above 10ppm so do not adjust until fc comes down.
With the cover off the daily UV demand is back. The sun isn't super high in the sky yet but it's enough that you'll have 70s Monday and Tuesday.
Either put the cover back on or use a submersible pump to disperse chlorine as needed.
I put the cover back on. I got the filter running today and added a bit of chlorine. I'll test later today and keep the winter cover on until I am ready to swim. The water temperature is 55 degrees F. It still needs a good vacuuming and scrubbing, but thanks to TFP, I'm feeling pretty confident this year!
Thank you. I wondered about the accuracy of the PH. However, my tap water's PH has been extremely high lately, so it's not all that surprising. Pool is looking great, but now I'm dealing with stains.
Yes, I overestimated the Liquid Chlorine requirement, but not by that much. According to the TFP SLAM Chart, at 60PPM CYA 24PPM should have been sufficient. Overnight that 33PPM was down to 19PPM. The next night was 17PPM. However, pool is crystal clear. I think I'll keep it around 20PPM for now until I only lose 1PPM overnight as recommended. The CYA has dropped to around 55PPM after vacuuming, cleaning and topping off the water.
Reactions: Mdragger88
Came to post amazing picture after removing our cover today. This is what it looked like underneath immediately after taking the cover off. Minds blown once again, as this is what it is like every year! We live in northern Illinois and closed our pool in October. So almost 6-7 months under a cover and look what beautiful water awaited us!! I love TFPC!
Opened on May 10th this year. Looks like this every year after I pull the cover. Had to wait for some test chemicals before I could get the water chemistry where it's supposed to be. Another day or so and the water will be back to crystal clear. Fired up the heat pump but I don't think there is enough heat out there yet. Supposed to be in the 90s here mid week so that will help.
Today was the day! Hoping to capitalize on the upcoming rain.
A bit of silt from my sieve of a cover 🤨But Roberta robot 🤖 is working feverishly on that now.
System has been running a few hours a day since April 9th so I have made my way up to slam level with the swcg.
Steps look a little dingy- may throw some sequestrant in after fc falls a bit.
Opening my pool after work today and I kind of hate most of you for your pools looking so great when opened. I did a bad close last year due to unforseen circumstances so i know its going to be nasty. As long as its not raining im cutting the grass then opening so i can leaf blow the grass away before popping the top lol.
Yeah but you weren't one of us yet, and now you are. So you have that going for you, which is nice.
When the time comes to close, get a thread going and tag me, @PoolStored, @Mdragger88 and/or anyone else you meet along the way who would be happy to help, and we'll hatch a plan to give you your best chances at opening. (We'd probably all see your thread if you post one, but tag us just in case we missed it).
I bought a house in February with this pool. I strongly suspect the cover hasn't been off in several years. I've no idea the water chemistry yet, I haven't gotten my test kit yet. What you see in the water is all sediment, it cleated almost completely with two days of running the filter (and two backwashes). The bottom is still covered in sediment in some places, A replacement drive belt for the in-pool cleaner is on order to take care of that.
Reactions: blazer58
