I got a little too lazy with testing my water.
Finally replaced my TFTest Kit and did a full test a couple of weeks ago.
My TA was 290! pH looked like 8.2...hard to tell if it goes higher than that.
I dumped a good bit of muriatic acid in to try to lower the TA/pH and then aerated.
TA is down to 190, but my pool has developed a chalky discoloration around the waterline tile.
1) Am I following the correct process to get my TA under control?
- add enough muriatic acid to bring the pH down to around 6.5 and then aerate
2) What is the best product to use to remove the chalky waterline stain/scale?
I searched the forum and didn't find quite what I was looking for, but if there is a post/thread where this issue is discussed (and hopefully resolved) I'm happy to start there.
Thank you!
Thank you!
