Lesson learned - Rust spots in pool
Randrx2
373
Orlando, FL
The other day I noticed a couple rust spots on the bottom of pool. No big deal, they pop up once in awhile. But then I noticed more and more. They were all mainly where the wall and floor meet. That seemed weird.
So I dove down with my vitamin C tabs and started rubbing the spots with the tabs. They were coming off easy.
As I was cleaning the spots, I noticed small metal fibers moving from the spot. Then it dawned on me! I realized this was from a few days ago when I did a SLAM. I had brushed the entire pool and also did some spot cleaning in the nooks and crannies with a small wire brush. It looks like pieces of the brush came off and caused the rust spots.
I will only be using a nylon brush for my detail scrubbing.
The vitamin C tabs are so simple and work!
This post is mainly information to help out others.
Have a great day!
Reactions: Nanifen
SouthVirginiaPool
104
Chesapeake, Virginia
Unrelated to pools - but I never use a wire brush on my grill anymore - those same wire bristles WILL fall off and may get stuck to a burger or steak you are cooking. A buddy of mine had to have surgery to remove a bristle that penetrated his throat in his upper neck.
  • Wow
Reactions: caligrl2
Newdude
4,510
NY
Same, but without the hospital trip. Got lucky and was stuck in the gums with a bristle.
Reactions: SouthVirginiaPool
bskaggs
8
Seattle/WA
felt something sharp on my pool robot, a piece of wire from the wire brush was lodged into part of it. now I notice the robot is picking up a few of these tiny wires often, like little needles. I will never use a metal brush again
