I have a pool that was put in about 5 years ago, LED lights that not used super often so I do not think it can be the bulbs. But last night went to turn on the lights for the kids and the spa works, but the two pool lights are not.
I did the standard checking the breaker, and the GFCI (however with the spa working and on same breaker shouldnt be a problem regardless).
I used a non contact voltage tested for the power line leading out the control panel down to the lights, and when I switch the light on, power starts flowing through that line- so it appears the lights are getting power. I would assume bad bulb- however its both pool lights, and they both have probably less then 100 hours on them.
Any ideas on what to test next?
Thanks!
Matt
Thanks!
Matt
