One of the sunseeker’s? Mine is starting to act a little flaky after ~18 months - at times it won’t change color even when I cycle on/off. Hoping it holds up a bit longer.
I hear you on the cables. One tip that was helpful to me: lube the cable generously with a silicone lube like magic lube ii. It’s messy but holds up well in the wet conduit, will go in easy and (hopefully) come out easily as well.
