Leaving pool unattended for 10 days in July
lauramor
Active member
Jan 25, 2022
41
Gilbert, AZ
Hello,
As the title says I will be going out of town and my pool will be unattended for 10 days. I don't have anyone who can come to test the water and add chlorine (unless I hire a company). I thought I would use pucks during those days, but I am wondering if that will actually work? Also, how many pucks should I put in the dispenser? Any other tips I should know of when doing this? Thank you in advance!
FC: 5
pH: 7.8
TA: 80
CH: 350
CYA: 40
I have a similar situation in July and I plan to:
- Raise FC to SLAM levels before I go
- Put a couple of pucks in a floating dispenser
- Leave my pump at its current run state (a couple of hours at high RPM, rest of time low RPM) to keep water moving
- Cover with the solar cover
What is your CYA currently? Mine is pretty low and I can handle the increase from a couple of pucks.
Reactions: AK- and Mdragger88
Thanks for your reply! My CYA is 40.
