Hey everyone,
I've got an issue where my pool drains/leaks very quickly to just above the return jets on the pool walls (about 5-6 inches below standard waterline) and then just stops. I've had a serviceman come out a few times and try to find the leaks but no luck. He now thinks it's in the pipes. My question is, if the leak is in the piping, shouldn't the water drain to below or at least somewhere in between the top/bottom of the jets? Right now it leaks very quickly to about 2cm above the jets and stops.
![IMG_5406 (1).jpg IMG_5406 (1).jpg](https://www.troublefreepool.com/data/attachments/69/69785-dc99058f8c54c771348a95c3b14663b1.jpg)
Thanks for the advice/perspective ahead of time.
