I was wondering if the 3/4 HP motor would save enough to make the impeller worth it.
I think to start I might just order the, Hayward SPX3000T Housing Gasket and the PS-3868 Seal Assembly. If the leak goes away then I'll order a new motor does that sound prudent?
If the motor is ok, then you might only need a housing gasket and seal. Edit - ok, I misunderstood. You just want to make sure that the leak is fixable before deciding on getting a new motor or whole pump. That makes sense.
Not sure it's worth changing out the impeller and motor, you're energy cost are pretty cheap, the saving is going from a single speed to a two speed. With a 2-speed on low you move 1/2 the water but at a 1/4 of the cost. I'd get a 2-speed 1hp, and keep your current impeller. The saving between a 3/4 and 1 hp isn't that great.
Hayward 2 SPEED MOTOR 1 H.P. - SPX1607Z2MS - INYOPools.com
The 2 speed motor is $360 vs $127 for the single speed.
At that point, you might as well buy the whole pump.
Hayward Super Pump 1 HP Dual Speed - SP2607X102S - INYOPools.com
Also, you have to know if the current pump is full rated or max rated to know the total hp needed.
The two speed motor is 230 volts only, so you have to make sure that that's what you have.
